HOWTO turn down the power on Cisco APs to reduce leakage?
rob.huffman Thu, 05/03/2007 - 05:33
Hi Chris,
Have you tried this method;
You can also start from the lowest possible power level and increase the level until you reach a consistent throughput. This is because in some cases, if you do not boost the signal to the maximum level, the throughput and signal strength can change continuously and not remain consistent.
Refer to Configure Radio Transmit Power for more information on how to configure the power level setting on the AP.
From this doc;
Hope this helps!
