CME with SIP Trunk and Cisco Unity Express
Paolo Bevilacqua Thu, 05/03/2007 - 04:02
  • Hall of Fame,
    Founding Member
Are the calls coming in with G.711? Nothing else would work with CME.
Does it fails only when transferred, or also when calling main VM number directly ? If the first, you may need to configure:
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
To confirm collect output of "debug ccsip message" with "term mon" to know a little more.
spazziani Fri, 11/18/2011 - 05:24
Hi Damm,
Did you solve your problem, because I'm having the same problem. Could you help me please ?
Vinicius
Arun Thomas Tue, 11/22/2011 - 04:13
Please check the dial-peer configs. Sample configs below.
dial-peer voice 200 voip
description CUE-Voicemail
destination-pattern 8000
b2bua
session protocol sipv2
session target ipv4:1.1.1.1
dtmf-relay sip-notify
codec g711ulaw
no vad
spazziani Wed, 11/23/2011 - 14:19
Arun Thomas,
I verified the dial-peer and it doesn't have two commands "dtfm-relay sip-notify" and "no vad". After I put both commands solved my problem.
Thank you very much.
Vinicius
Arun Thomas Thu, 11/24/2011 - 00:18
Happy to see that your issue is resolved. but i dont think that its the dtmf command but may be the "no vad"
Please rate post if it does!
