CSA executable packaged into MSI
May 2nd, 2007
Hi:
Wondering if anyone has packaged the CSA 5.x client EXE into an MSI for deployment via Group Policy. If successful, would you please share the tools/process used to create the MSI. Thank you.
codycornell Thu, 05/03/2007 - 07:29
We wanted to do the same thing with Tivoli but according to Cisco using a MSI package with CSA v5.1.0.79 and earlier is not suggested, I'm not positive about later versions. Past experience showed that the initial installation was not a problem, but over the long term they ran into issues they associated with the MSI installation. So specifics I don't have but the vendor recommendation is to install as an executable.
