Cisco 1841
May 2nd, 2007
Router 1841 doesn;t show temperature status when I run command sh env whereas 2800 is showing.The IOS is 12.4 on both
Kindly suggest??
Output:
sh env
FAN 1 Running sucessfully
ILP Power Supply - Absent
Paolo Bevilacqua Thu, 05/03/2007 - 08:17
the 18xx does not support temperature monitor, where did you saw differently ?
hope this helps, please rate post if it does!
tahseen12 Sat, 05/05/2007 - 20:14
Do you have any link saying this
It works on 2800 but not in 1800
Paolo Bevilacqua Sun, 05/06/2007 - 04:32
1800 and 2801 does not have a temperature sensor.
2811 and bigger models do have.
This is the way it is.
Paolo Bevilacqua Mon, 05/07/2007 - 01:37
I think you have misread the document. It does not says that the 1800 has a temperature meter, it simply says that the FAN is temperature-controlled:
Cisco 1800 series fixed-configuration routers have an internal multispeed fan that provides chassis cooling, controlled by an onboard temperature sensor. The internal fan operates at a continuously variable speed to minimize fan noise while providing sufficient chassis cooling.
So you can go around as much as you want, no thermometer, sorry.
