3750 switch
May 2nd, 2007
we have 3750 switch its getting restart atmatcaly. for every 2 hrs .power is ok
but switch is booting automaticaly .its the main switch for our office.pls give me some solutions.
ankbhasi Wed, 05/02/2007 - 21:45
Hi Friend,
It is bit difficult to find out the reason of restart with the information you have posted.
Is it possible for you to check the logs, or some errors if you observe , or some crash file. If possible can you console into the switch and start capturing all events so that once it reboots again we can see what event triggered the reboot.
Can you also check the cpu utilization with command "sh proc cpu".
Anand S Thu, 05/03/2007 - 03:35
Hi Idesign,
if you explain what exactly happend to you switch, i will be in a position to guide you, send me the tech-support information which will have the complete info.
forticis Thu, 08/16/2007 - 11:03
Was your 3750 booting problem solved. please let us know the solution
