Warning message
get_shanu Wed, 05/02/2007 - 22:52
Recommend you to check your media first and then workout to find out if your interface is getting Jumbo packets. Larger packets sometime cause the problem..
cisconoval Wed, 05/02/2007 - 23:04
Thanks for your reply
Can you please tell is there any software to check the packets?
kumar.ajeet Thu, 05/03/2007 - 05:14
You can check the load of the interface with the help of "Show interface" command.
You can find the Rx & Tx of the interface.
Please rate if it does help.
Ajeet
kumar.ajeet Thu, 05/03/2007 - 05:08
In a first look it seems there could be loose contact or might be the ethernet port has gone bad.
You can use "debug fastethernet {events | packets}" command for more information.
Please rate if it does help,
Ajeet Kumar
