enterprise monitoring software
carl_townshend
Hi all, my company is thinking of buying some software to monitor, wan, lan, servers etc, Is there any good ones I should know about?
cheers
Carl
Danilo Dy
Try NAGIOS http://nagios.org/
Dandy
avmabe
Level 3
Level 3
There are literally hundreds of commercial and open-source solutions to meet your needs. I would recommend you try out some demos of commercial products before purchase. I also recommend downloading and installing free open source programs and seeing if they fit your needs.
This will help you come up with the best solution for your company. Nagios was mentioned... Also Cacti http://cacti.net.
One I highly suggest incorporates multiple oss products...
http://www.groundworkopensource.com/
