CiscoWorks 2.2 ---- CiscoWorks 2.5
May 3rd, 2007
Hi, Is there a migration tool that can migrate the old Cisco Works 2.2 config file to 2.5 ?
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 05/04/2007 - 11:41
Dave's reply about the data migration guidelines is the way to go. When you restore for LMS 2.2 backup into LMS 2.5+, it will automatically migrate the data for you. I would also add that there have been more migration bugs fixed in LMS 2.6 which is a free download that applies on top of LMS 2.5.1 (see You should consider applying that before doing your 2.2 migration.
But when you do decide to do it, make sure you carefully read the guidelines in the previous post by davistan.
