05-03-2007 01:49 AM - edited 03-03-2019 04:48 PM
Dear Expert,
I am very new to CISCO, How to setup QOS on CISCO 3640, 2620 & 1760.. below are my IOS versions.
Many thanks in advance
Winanjaya
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(4)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 28-Sep-01 05:01 by ccai
Image text-base: 0x600089A8, data-base: 0x61428000
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(4)T, RELEASE SOFTWARE (fc1)
Compiled Fri 28-Sep-01 06:59 by ccai
Image text-base: 0x80008088, data-base: 0x812E7ADC
IOS (tm) C1700 Software (C1700-SV3Y-M), Version 12.2(4)XW, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Compiled Wed 14-Nov-01 01:18 by ealyon
Image text-base: 0x80008124, data-base: 0x80CA8C08
Solved! Go to Solution.
05-04-2007 12:11 AM
We can classify them according to the IP addresses of the servers (once as source and once as destination), but in this case all the traffic from and to the servers will be treated the same way.
HTH, please rate all helpful posts,
Mohammed Mahmoud.
05-03-2007 01:59 AM
What QoS parameters exactly that you require to configure, and what is the type of traffic in your network.
BR,
Mohammed Mahmoud.
05-03-2007 02:22 AM
Thanks, What i need is to configure QOS for the following:
- Client Server Application 1
- Client Server Applicaiton 2
- Internet Browsing
FYI, Our mail & proxy server are located at HO
many thanks in advance
Winanjaya
05-03-2007 02:29 AM
What is the connectivity technology between the routers (FR, MPLS, leased, ...), what is the bandwidth of each site, and what is the bandwidth that you wish to guarantee for each traffic type.
BR,
Mohammed Mahmoud.
05-03-2007 02:40 AM
Connectivity between routers is E1 leased line channel
HO to Branch A is 2 MB
HO to Branch B is 2 MB
HO to Branch C is 2 MB
HO to Branch D is 2 MB
HO to Branch E is 2 MB
this is for example:
Mail: 25%
Client Server Application 1 : 15%
Client Server Application 2 : 15%
Internet Browsing : 25%
Others : 20 %
Others meant undefined services.
Winanjaya
05-03-2007 03:18 AM
Here you are a basic QoS configuration.
For your knowledge the QoS doesn't interact unless there is congestion on the link.
First Define the classes (for mail use the protocols you require from the following, for app1 and app2 use an extended ACL to define them)
class-map match-any mail
match protocol pop3
match protocol smtp
match protocol imap
match protocol secure-pop3
match protocol secure-imap
match protocol exchange
match protocol ldap
class-map match-all http
match protocol http
class-map match-all app1
match access-group 101
class-map match-all app2
match access-group 102
Assign each traffic class the appropriate bw:
policy-map qos
class mail
bandwidth percent 25
class http
class app1
bandwidth percent 15
class app2
class class-default
fair-queue
You then need to classifiy app1 and app2 traffic may be according to the port number used:
access-list 101 permit tcp any any eq
access-list 101 permit tcp any eq
access-list 102 permit tcp any any eq
access-list 102 permit tcp any eq
Apply the policy under each interface in the output direction:
interface serial 0/0
bandwidth 2048
service-policy output qos
I hope that i've been informative.
HTH, please rate using the below scroll box if it does help,
Mohammed Mahmoud.
05-03-2007 05:21 PM
Hi..
You wrote:
... the QoS doesn't interact unless there is congestion on the link...
did you mean that if there is no congestion on the link then the first come class will get full bw regardless the QOS ? pls advise
thanks & regards
Winanjaya
05-03-2007 08:54 PM
Hi Winanjaya
Whatever Mohammed told you is a congestion management which is one of many methods of QOS implementation. If your link isn't congestion(Hardware Queue full) then software queuing that you configured won't be used at all.
L.Thot
05-03-2007 10:23 PM
Hi Winanjaya,
Yes what i meant is that the congestion management tools that we've configured till now will only interact when there is congestion, which is fair, in the case that there is no congestion any traffic of them can talk more than what was guaranteed for him which is nice, but in the moment of congestion the values we configured are met, which is what we are looking for.
HTH, please rate if it does help,
Mohammed Mahmoud.
05-03-2007 11:56 PM
How about for App1, App2 they don't have static service port
05-04-2007 12:11 AM
Mohammed Mahmoud.
