05-03-2007 03:58 AM - edited 03-03-2019 04:48 PM
Hi everybody,
I have a Cisco 7507 chassis with two RSP4+ processors running 12.3(18) image. Is it possible to swap active/slave processor issuing a CLI command? Otherwise how can I force this swap?
Stefano
05-03-2007 04:25 AM
To switch control of a router from the active to the standby Route Switch Processor (RSP), use the redundancy force-switchover command in privileged EXEC mode.
Bjornarsb
05-03-2007 04:30 AM
Router# redundancy force-switchover
Forces a switchover to the standby RSP.
NOTE: Both the active and standby RSPs must have a high availability Cisco IOS image installed and must be configured for RPR redundancy mode before the redundancy force-switchover command can be used.
HTH, please rate if it does help,
Mohammed Mahmoud.
