PIX 7.0 inspect
May 3rd, 2007
As you are all aware, by default the 'inspect sqlnet' feature is switched on under the global policy map on PIX v7 firewalls.
I would like to keep the 'inspect sqlnet' feature on at the global policy level, but turn it off for traffic travelling between a specific source/destination network using access lists.
Is this possible? If so, could someone please provide some guidance on how to do this?
Many Thanks
vijayasankar Thu, 05/03/2007 - 22:00
  • Silver, 250 points or more
You can achieve that by configuring a layer3/4 policy and bind it to an interface.
Policy binded to the interface will take precedence than the gloabal default inspection policy.
Have a look at this URL for more details.
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a008063706a.html
For example: You can configure as follows
Define a acl, to exclude the traffic between source and destination network and then permit everything else.
Create class map and match this ACL in it.
Create a policy-map, call this class-map and perform inpsect sqlnet for the matching traffic in the class-map.
Bind this policy-map to the appropriate interface.
Sample configuration
access-list sqlnettraffic deny ip
access-list sqlnettraffic permit ip any any
class-map my-sqlnet-traffic
match access-list sqlnettraffic
policy-map my-sqlnet-policy
class my-sqlnet-traffic
inspect sqlnet
service-policy my-sqlnet-policy interface outside
This should help to acheive what you are looking.
Hope this helps.
-VJ
amcneish Fri, 05/11/2007 - 13:40
Just a follow on question.. what would be the difference if once just modified the SQL behaviour in the global policy instead .. with access lists.. etc
vijayasankar Fri, 05/11/2007 - 20:56
That will affect for all the SQL traffic passing through the firewall.
What is your exact requirement? Why do you want to disable the SQL inspect feature.?
-VJ
amcneish Sat, 05/12/2007 - 04:30
I was interested in the original request to permit the remote site to perform the permit of the SQL traffic..
If one only has an outside and an inside.. then using the global should be about the same as putting it on the outside interface.. (is that correct??)
If one has many DMZ's.. then one could put it on the outside.. or possibly one of the DMZ's (is that also correct??)
We recently upgraded for Pix 525's to ASA 5540's and we are new to the policy statements and answers to the above questions would go a long way to giving us insight.
Andy
