CM 4.0.6 User tracker/vrf network
Answered Question
May 3rd, 2007
Any idea why ut cant see ip vrf forwarding network. Ut does not show end hosts of that vrf network hosts at all.(no mac adress of ports and nothing at all) Vrf router is WS-C6506-E and end users are connected to WS-C4507R switch.
SNMP goes okay to both switches from LMS server(E.g. snmpwalk)
Vrf router WS-C6506-E does not show mac adresses/ip addresses of those end hosts if i enter "sho arp". If i enter "sho ip arp vrf [Forwarding instance name} i can see all end hosts mac and ip information.
thanks
Juha
Correct Answer by Martin Ermel about 9 years 11 months ago
Yes, this is the main problem. The current process only uses this MIB to get the required information from the router and you cannot change this behaviour. You have no chance to change this process of CM - you rely on a patch or upgrade from Cisco on this issue! (...it is more a feature enhancement...)
Overall Rating: 4.8 (3 ratings)
Martin Ermel Thu, 05/03/2007 - 05:10
  • Blue, 1500 points or more
this paper was written for Campus 3.x but the basic principals are still the same:
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml#s7
there you can read:
"ANI contacts each router connected to the subnet of the discovered host and queries the ARP table using the ipNetToMediaEntry table from the RFC1213-MIB. ARP tables are often very large. ANI only polls those interfaces that are connected to subnets where hosts are discovered. "
And I don't think that the RFC1213-MIB does have any information about vrf arp tables ...
I assume, that currently there is no process implemented in campus to support this functionality...
the question is "is it planned??"- when I asked I never did get an answer...
this could become a big issue for UserTracking as more and more enterprise customers implement MPLS;
Joe Clarke Thu, 05/03/2007 - 07:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
All I can say is that this is planned. However there is no estimated date for integration, and the roadmap could change at any moment.
Martin Ermel Thu, 05/03/2007 - 22:19
thanks for this info!
I think this point should be pushed forward a little more. I know that this is always an issue for customers when they discuss the introduction of MPLS in their network - is LMS ready to still meet the needs? If not they start thinking and looking around for alternatives...
UT is one of the mostly loved apps in LMS.
u346874_2 Thu, 05/03/2007 - 23:14
And thanks for answers. Is the main problem the vrf arp table which is not included to RFC1213-MIB or should i look into somenthing else. Both switches are reachable state i CM.
Juha
Correct Answer
Martin Ermel Fri, 05/04/2007 - 01:16
