Linkdown trap not working
May 3rd, 2007
hi,
I am trying to monitor 2621 with IOS 12.1(5)T but i discoverd that it doesn't send a link down trap.
i checked the configuration and it looks fine (It is working on other routers).
Could you help me (Configuration is attached).
Tzachi Slav
Configuration
Version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hosname R_X
no logging rate-limit
ip subnet zero
no ip finger
ip domain name test.sm
ip name-server 222.x.x.240
decnet routing 1.504
decnet node-type are
call rsvp-sync
interface loopback0
ip address 200.x.x.x.255.255.0
interface fastethernet 0/0
description LAN
ip addess 222.222.x.x.255.255.0
duplex auto
speed auto
decnet cost 1
ip rsvp bandwidth 24 24
interface serial 0/0
description WAN
mtu 1000
bandwidth 64
ip address 222.x.x.3 255.255.255.0
ip tcp header-compression
no ip mroute-cache
dcnet cost 2
fair-queue 64 16 1
mop enabled
ip rtp header-compression
ip rsvp bandwidth 24 25
router eigrp 1
no auto-summary
no eigrp log-neighbor-changes
ip classless
no ip http server
decnet host MRRTR4 1.504
snmp-server engineID local X
snmp-server community public RO
snmp-server community password RW
snmp-server trap-source loopback0
snmp-server enable traps snmp authentication linkdown linkup coldstart
snmp-server enable traps hsrp
snmp-server enable traps syslog
snmp-server host 222.x.x.222 password xxx config envmon syslog
end
Overall Rating: 4 (1 ratings)
David Stanford Thu, 05/03/2007 - 05:21
If you enable snmp debugs do you see it attempt to send the snmp link down trap?
If so, what is the network path to the trap receiver? Any chance it is getting dropped after leaving this device?
Nigel Bowden Thu, 05/03/2007 - 06:07
Just try:
snmp-server host 222.22.211.222 password
I think the 'tty config envmon syslog' parameters are maybe stopping the link up/down traps.
David Stanford Thu, 05/03/2007 - 07:44
Sorry I missed that...your config will not send snmp linkup/down to the host based on the paramaters you added to the host command
