Cat6500 (sup720) config-register set to 0x3920 can't console in HELP!!!!
I was trying to restore a deleted image on a 6500/sup720, upon researching viz the web I changed the config-register to 0x3920 and now i cannot console into switch. I tried changing the terminal speed to 115k, no luck. im totally locked out of switch and not sure what to do....can someone help? im sure it's an easy answer. Thanks.
Overall Rating: 4 (1 ratings)
mohammedmahmoud Thu, 05/03/2007 - 06:22
  • Green, 3000 points or more
Please try changing the baud rate of the terminal 115200 console baud rate, it should work if not you'll have to try other values until you can break to the rommon and change the config-reg from this to the ordinary 0x2102.
HTH, please rate if it does help,
Mohammed Mahmoud.
