Port errors
can anyone help debug this problem, my users will be on working fine and will then the connection will get terminated this can happen after 30sec or 4 hrs of connect time. the following errors are int the event log
CTX: 0x490055: Error(3/17): Detected error in SG protocol
and
Session Type: SSL VPN Client
Duration: 0:40:17
Bytes xmt: 967081
Bytes rcv: 520977
Reason: Port Error
thanks for any help or pointing me in the right direction.
j-block Wed, 05/09/2007 - 10:01
It appears that the problem is not with the SSL client but probably a bad connection which appears to be dropping the connection (this would force the Port Errors).
David Stanford Thu, 05/10/2007 - 05:11
  • Cisco Employee,
Are you behind any type of proxy server like NetCache Proxy Server? Also, have you disabled routing and remote access service on the computer?
