UdpJitter(codec) configuration using SNMP
Answered Question
May 3rd, 2007
Who can told me order of setting objects for UdpJitter(codec)operation?
For example following is order of setting objects for UdpJitter without codec:
rttMonCtrlAdminRttType.<index> -Integer 9
rttMonEchoAdminProtocol.<index> -Integer 27
rttMonEchoAdminTargetAddress.<index> -OctetString "05 00 00 02"
rttMonEchoAdminTargetPort.<index> -Integer 8000
rttMonEchoAdminInterval.<index> -Integer 20
rttMonEchoAdminNumPackets.<index> -Integer 100
rttMonCtrlAdminStatus.<index> -Integer 4
rttMonScheduleAdminRttStartTime.<index> -TimeTicks 1
Thanks ahead
Correct Answer by Joe Clarke about 9 years 12 months ago
You can insert the rttMonEchoAdminCodecType just before rttMonCtrlAdminStatus. However, you cannot specify rttMonEchoAdminPktDataRequestSize, rttMonEchoAdminInterval, or rttMonEchoAdminPackets if you specify a codec. See the CISCO-RTTMON-MIB for more details.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 05/03/2007 - 09:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
