3560's not routing...
May 3rd, 2007
Can anyone please tell me why these two 3560's are not routing?
Test#sh run
Building configuration...
Current configuration : 2605 bytes
version 12.2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/17
no switchport
ip address 192.168.1.1 255.255.255.252
interface Vlan1
ip address 10.90.153.1 255.255.255.0
router eigrp 1
network 10.90.153.0 0.0.0.255
network 192.168.1.0 0.0.0.3
auto-summary
ip default-gateway 10.90.153.200
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/17
E3#sh run
Current configuration : 2816 bytes
version 12.2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
no switchport
ip address 192.168.1.2 255.255.255.252
interface GigabitEthernet0/48
switchport mode trunk
duplex full
macro description cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
interface Vlan1
ip address 172.23.31.34 255.255.255.224
router eigrp 1
network 172.23.31.32 0.0.0.31
auto-summary
ip default-gateway 172.23.31.33
ip classless
ip route 0.0.0.0 0.0.0.0 172.23.31.33
chris.lepa Thu, 05/03/2007 - 11:57
I'm not too sure what you're issue is, "not routing" is a pretty vague statement. Are your devices forming eigrp neighbor relationships? If so, it may be an issue with "auto-summary". In eigrp configuration, type "no auto-summary" so you're networks aren't summarized at the classful boundary.
-Chris
ricschaaf Thu, 05/03/2007 - 12:07
Thanks for responding.
I can't ping from the 172.23.31.32/27 net
to the 10.90.153.0/24 net
Attached is a screen shot of the routing tables of one of the switches
chris.lepa Thu, 05/03/2007 - 12:26
Well, it seems that the 10.90.153.0 network is not in your eigrp routing table at all, meaning that anything destined for that network will use the static route you have applied (ip route 0.0.0.0 0.0.0.0 172.23.31.33). I'm not exactly sure what this route is doing... Is there more than the 2 devices stated in this network?
-Chris
ricschaaf Thu, 05/03/2007 - 13:04
There is a router attached to port 48 that
is the default gateway for the whole network.
I turned off auto-summarization on the switch named Test and it now shows the 172.23.31.32/27 net in it's routing table,
but when I did it on the switch E3, it did not pick up the 10.90.153.0/24 net.
Current configs and tables attached.
Thanks for your help,
Ric
E3#sh run
Current configuration : 2819 bytes
version 12.2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
no switchport
duplex full
auto qos voip trust
interface Vlan1
router eigrp 1
no auto-summary
ip classless
Test#sh run
Current configuration : 2600 bytes
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
no switchport
interface Vlan1
router eigrp 1
no auto-summary
ip classless
chris.lepa Thu, 05/03/2007 - 13:21
Based on your EIGRP configuration, I can't see anything wrong. I DO see a problem with your static default route on Test though.
Neither "ip route 0.0.0.0 0.0.0.0 172.23.31.33" or "ip default-gateway 172.23.31.33" should be configured on Test because that is not a next hop address this router is familiar with.
Instead, I suggest that you enter the "default-information originate" or "redistribute static" command in EIGRP on your E3 router. This maaaay fix your issues.
-Chris
chris.lepa Thu, 05/03/2007 - 13:31
Oh, you should also check to see if Vlan 1 is even UP on Test. This route wont get advertised by EIGRP if the SVI is down, might want to check that out too if the previous solution doesn't do anything.
ricschaaf Fri, 05/04/2007 - 05:59
VLAN 1 is up on Test. I can connect a client as 10.90.153.x
and ping the E3 switch at 172.23.31.34, but no other IP's
on that 172.23.31.32/27 net.
I changed the default on Test as shown below and no luck.
There's something on the E3 switch that is not right.
I even tried making VLAN 1 passive on E3 and no luck.
Thanks, Ric
Test#sh run
Current configuration : 2575 bytes
version 12.2
ip subnet-zero
ip routing
no file verify auto
no switchport
interface Vlan1
router eigrp 1
no auto-summary
ip classless
Test#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
172.23.0.0/27 is subnetted, 1 subnets
D 172.23.31.32 [90/3072] via 192.168.1.2, 16:54:44, GigabitEthernet0/17
10.0.0.0/24 is subnetted, 1 subnets
C 10.90.153.0 is directly connected, Vlan1
192.168.1.0/30 is subnetted, 1 subnets
C 192.168.1.0 is directly connected, GigabitEthernet0/17
S* 0.0.0.0/0 is directly connected, GigabitEthernet0/17
E3#sh run
version 12.2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
no switchport
duplex full
auto qos voip trust
interface Vlan1
router eigrp 1
no auto-summary
ip classless
E3#show ip route
Gateway of last resort is 172.23.31.33 to network 0.0.0.0
C 172.23.31.32 is directly connected, Vlan1
S* 0.0.0.0/0 [1/0] via 172.23.31.33
Amit Singh Fri, 05/04/2007 - 06:42
Its a strange situation which is happening. EIGRP is making a neighbor relationship as far as " Test " switch is concerned. What happens when you issue " show ip eigrp neighbor " on E3 switch. Do you see the test listed a neighbor.
Here are the two things that we can try:
1.Try changing the connection between the 2 switches to a vlan SVI instead of using the routed port.Let us check if the eigrp neighbor relationship comes up.
2.Try debugging thye rigrp relationship and attach the debugs.
-amit singh
ricschaaf Fri, 05/04/2007 - 10:16
E3>show ip eigrp neighbor
IP-EIGRP neighbors for process 1
H Address Interface Hold Uptime SRTT RTO Q Seq Type
(sec) (ms) Cnt Num
0 192.168.1.1 Gi0/17 12 21:41:42 5 200 0 12
On suggestion #1, do you mean connect them together without using the 192.168.1.0/30 net?
Thanks, Ric
chris.lepa Fri, 05/04/2007 - 10:25
He means:
Test#
int vlan 192
ip add 192.168.1.1 255.255.255.252
no shut
int gi0/17
switchport mode access
switchport access vlan 192
E3#
int vlan 192
ip add 192.168.1.2 255.255.255.252
no shut
int gi0/17
At least I think he means that... Give it a shot and get back to us.
-Chris
Amit Singh Fri, 05/04/2007 - 10:45
Yeah. I meant the same as posted by Chris. The output in your earlier post shows that E has a succesful naighbor relationship with test.Please paste the output of " show EIGRP topo " from the E3.
Also let me know the IOS version that your are running on 3560's.
-amit singh
ricschaaf Fri, 05/04/2007 - 12:20
E3>show ip eigrp topo
IP-EIGRP Topology Table for AS(1)/ID(192.168.1.2)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 192.168.1.0/30, 1 successors, FD is 2816
via Connected, GigabitEthernet0/17
P 172.23.31.32/27, 1 successors, FD is 2816
via Connected, Vlan1
version 12.2
E3 is not picking up the 10.90.153.0/24 net in it's routing table. Diagram is attached.
Thanks, Ric
ricschaaf Fri, 05/04/2007 - 12:39
I really wnat to fihure this out....
Here's what Test looks like:
Test>show ip eigrp topo
IP-EIGRP Topology Table for AS(1)/ID(192.168.1.1)
P 172.23.31.32/27, 1 successors, FD is 3072
via 192.168.1.2 (3072/2816), GigabitEthernet0/17
P 10.90.153.0/24, 1 successors, FD is 2816
Thanks very much, Ric
sundar.palaniappan Fri, 05/04/2007 - 12:57
Did you at any point had an interface on router E3 configured with an IP from 10.90.153.0/24 subnet?
ricschaaf Fri, 05/04/2007 - 13:08
Actually, yes. Once upon a time I did config one
of the ports on E3 with an address from the
10.90.153.0/24 net. It has been long removed.
Why would that cause a problem? Does something
remain in the system?
Here's the latest from E3:
E3#sh run
Current configuration : 3191 bytes
version 12.2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
no switchport
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
duplex full
auto qos voip trust
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet0/52
interface Vlan1
interface Vlan192
no ip address
router eigrp 1
no auto-summary
ip classless
sundar.palaniappan Fri, 05/04/2007 - 13:22
Configure the command 'no ip split-horizon eigrp 1' under g0/17 int on Test router. Then clear the eigrp neighbor and routes and see if that helps.
Sundar
