No Carrier Detect T1 CSU/DSU WIC 2600 Router
May 3rd, 2007
When we loopback the WIC, the far end sees a good connection, but when the loopback is released, the CD LED goes out.
Crossed wires maybe?
It's a remote site, so I have not double checked yet.
Paolo Bevilacqua Thu, 05/10/2007 - 12:36
Yes, crossed wires would behave like that.
hope this helps, please rate post if it does!
KEVALSONP Thu, 05/10/2007 - 12:37
I will check.
It will be not this Friday, but next.
I will post back what I find.
scottmac Thu, 05/10/2007 - 13:53
Protocol mismatch would also behave like that (i.e., PPP on one side, HDLC or Frame-Relay on the other).
Good Luck
Scott
Paolo Bevilacqua Thu, 05/10/2007 - 14:04
Scott, I wouldn't agree. On a L2 protocol mismatch you will have LEDs OK, controller and interface up, line protocol down.
