Connecting two 3560 PoE's together
May 3rd, 2007
I want to connect two 3560 PoE switches together via that special SFP Module Patch Cable.
I'm not sure what is the most efficient way to configure the switches. They will both function as simple access switches at one of my remote locations. This facility is running on one switch, but needs more ports now.
Back a Corp. I've always Ether channeled my access switches back to the core switch.
What do you advise?
Overall Rating: 5 (1 ratings)
ankbhasi Thu, 05/03/2007 - 10:40
Hi Friend,
If you have multiple vlan configured on that remote location and you want the switches to pass data multiple vlans then you can configure trunk between these 2 switches.
Something like this
config t
interface
switchport mode trunk
You need to run the same commands on another switch interface which will be connected to this switch interface.
Ankur
*Pls rate all helpfull post
