05-03-2007 12:17 PM - edited 03-03-2019 04:49 PM
I am using a Cisco 2620 router. It currently has 64MB of DRAM and 16Mb of flash. I am going to use IOS 12.3.22. Will this router support BGP in that configuration? Do I need more DRAM and Flash memory?
Solved! Go to Solution.
05-03-2007 12:46 PM
Yes it should do it.
you are welcomed, and please check the attached diagram for IOS feature sets.
HTH, please rate if it does help,
Mohammed Mahmoud.
05-03-2007 12:21 PM
You should get a SP Serivce or Advanced IP Service, or Enterprise Services or Advanced Enterprise Services IOS feature set, to have BGP supported, and when you download it from Cisco, the RAM and flash requirement is stated.
Mohammed Mahmoud.
05-03-2007 12:31 PM
Will IP Plus work? I am new to Cisco networking and still trying to understand what SP Service, Advanced IP Service, Enterprise Services, and Advanced Enterprise Services mean.
05-03-2007 12:46 PM
05-03-2007 01:08 PM
It appears the IP Plus IOS 12.3.22 requires more DRAM and Flash than I have. Would anything lesser work?
05-03-2007 01:16 PM
Try the SP services, or try going down with the IOS release itself (maybe 12.2).
Mohammed Mahmoud.
05-04-2007 05:04 AM
I will try that. What I am ultimately trying to understand is what IOS do I need to run BGP to support my MPLS network on a 2620 router.
05-04-2007 06:38 AM
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
go to above link and click on the search by feature and then try to search with your hardware platform for the specific feature you will get the appropriate IOS list which is supported by your router with memory details...
