CVDM java.lang.NullPointer error
Answered Question
May 3rd, 2007
Anyone experience the error, java.lang.NullPointer when trying to load Cisco View Device Manager on a 6509-E?
Running: 122-18.SXF8
Tried both CVDM version: cvdm-c6500-1.1.tar & cvdm-c6500-1.1_K9.tar
Have Java installed: 1.4.2_06
Correct Answer by jreekers about 10 years 3 weeks ago
Hi.
I believe you're hitting a known bug:
CSCsc10956 - CVDM 1.1 does not work with 12.2(18)SXF
Release-note: CVDM 1.1 does not work after logging in on a Sup720 running IOS version 12.2(18)SXF within a 6500 switch.
I do see that there may be a patch for this issue, for which you would need to open a TAC case to obtain. Otherwise there is the following workaround:
Workaround: Downgrade the IOS software to 12.2(18)SXD3.
HTH,
-Joe
Overall Rating: 5 (1 ratings)
Correct Answer
jreekers Fri, 05/04/2007 - 09:32
  • Cisco Employee,
Hi.
HTH,
-Joe
