FTP behind a pix515
May 3rd, 2007
Ok, I am trying to have an FTP server (eFTP if it matters) in my web dmz. Basically have the server with a private performing NAT to a public address, no big deal, I have enabled the appropriate port for forwarding (21) - and I can set what other ports my server uses for data transfer etc, however I CANNOT get this thing to work. Anyone have a good resource to look at? I know the passive - active mode comes into play but I havn't found any good docs. I have enable ALL ip traffic from the client ip address to the server and still nothing - I must be missing something!
Thanks, elliott
Wizzle Thu, 05/03/2007 - 20:18
Do you have an inspect ftp in your config.You can add that line if you using 7.0 and above and see how it goes.
mseou Fri, 05/04/2007 - 05:02
I am running 7.2(2) - I will try the inspect option.
Thanks, Mike
