can't ping out router1 from router2
Answered Question
May 3rd, 2007
Hello all. I have router bcbehind connected to my cable modem. I can ping out and resolve domain names. bcnetworked is connect to bcbehind via serial connect. ser0 connects to ser0. I am able to ping from bcnetworked up to the cable modem. I can't ping out. I believe it is something with bcbehind's config any help would be appreciated.
Current configuration : 1060 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname BCBehind
logging queue-limit 100
enable secret xxx
ip subnet-zero
ip domain-name lookup
ip name-server x.x.x.x
partition flash 3 8 4 4
interface Serial0
ip address 10.0.0.1 255.255.255.252
interface Serial1
no ip address
shutdown
interface Serial2
no ip address
shutdown
interface Serial3
no ip address
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
ip address 192.168.0.2 255.255.255.0
ip nat outside
full-duplex
router rip
version 2
network 10.0.0.0
network 192.168.0.0
no auto-summary
ip default-gateway 192.168.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 10.0.0.0 255.255.255.252 192.168.0.1
ip route 192.168.0.0 255.255.255.0 192.168.0.1
no ip http server
line con 0
line aux 0
line vty 0 4
password xxx
login
end
Correct Answer by mohammedmahmoud about 9 years 11 months ago
Ok, thats the catch, you'll need to NAT bcnetworked IPs on the cable modem.
HTH, please rate if it does help,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
mohammedmahmoud Thu, 05/03/2007 - 13:02
  • Green, 3000 points or more
Can you post bcnetworked configuration.
BR,
Mohammed Mahmoud.
bruce.cowan Thu, 05/03/2007 - 13:16
Certainly:
Current configuration : 1290 bytes
version 12.2
hostname BCNetworked
enable secret 5 $1$rQob$U2mhmJ0CBl6WJ8wwBh5Lv1
ip subnet-zero
partition flash 2 8 8
interface Ethernet0
no ip address
shutdown
interface Ethernet1
no ip address
shutdown
interface Ethernet2
no ip address
shutdown
media-type 10BaseT
interface Ethernet3
no ip address
shutdown
media-type 10BaseT
interface Ethernet4
no ip address
shutdown
media-type 10BaseT
interface Ethernet5
no ip address
shutdown
media-type 10BaseT
interface Ethernet6
no ip address
shutdown
media-type 10BaseT
interface Ethernet7
no ip address
shutdown
media-type 10BaseT
interface Serial0
bandwidth 64
ip address 10.0.0.2 255.255.255.252
clockrate 64000
interface Serial1
no ip address
shutdown
interface Serial2
no ip address
shutdown
interface Serial3
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.1
no ip http server
line con 0
line aux 0
line vty 0 4
password 7 05485723334D195B485C46405858
login
end
mohammedmahmoud Thu, 05/03/2007 - 13:26
If i understand you right then BCNetworked can ping both bcbehind and the cable modem, but it can't get outside, you have to consolidate one thing, routing is a 2 way process, thus for a ping to succeed the packet must know how to go from BCNetworked to outside and then back from outside to BCNetworked, does the outside (your provider) route the IPs of BCNetworked back, or are you doing NAT on the cable modem and the IPs of BCNetworked is not included.
Mohammed Mahmoud.
Correct Answer
mohammedmahmoud Thu, 05/03/2007 - 13:59
Mohammed Mahmoud.
bruce.cowan Fri, 05/04/2007 - 09:27
That was very helpful. I was able to determine at the issue is my cable modem will not allow to allow any other networks other then the 192.168. network. Because of this I had to subnet the 192.168.0.0 to accommodate my needs since the cable modem would not allow me to enter the 10.0.0.0 network. Now both of my routers can ping all the way through. I appreciate the help.
B
mohammedmahmoud Fri, 05/04/2007 - 10:36
You are welcomed, i am glade that you have done it :)
BR,
Mohammed Mahmoud.
