Cisco CME to SIP Proxy
chris.moore
Hello, I have two 7940 phones running SCCP with CME 3.3 on a 2611XM Router. I'm trying to use my SIP phone number for the primary phone number using the SIP-UA in CME. So far the SIP-UA is registered and I can dial the sip number and both phones ring, but my problem is that I cant dial out from any phone. I have tried a few different dial-peers but i still cant dial out. Any help would be greatly appreciated. Thankyou. Chris.
paolo bevilacqua
Hi Chris,
to which SIP proxy are you connecting ? Most likely they want authentication, have you configured that under sip-ua ?
Please enable "term mon" and "debug ccsip message" for a failed call and that will tell you what is going wrong.
