voip and tandem connection
May 3rd, 2007
Here is the scenario;
1000-fxs-RA--IP--RB--IP--RC-fxs-3000. I
RA:
Dial peer 100 voip
destination-pattern 3000
sess target ipv4:RB
Rb:
Dial peer 100 voip
sess target ipv4:RB
Will 1000 able to call 3000 via this tandem connection? I have to do this for a very special reason. Thanks
Overall Rating: 4.5 (3 ratings)
paolo bevilacqua Fri, 05/04/2007 - 00:40
  • Hall of Fame,
    Founding Member
this "tandem" is called IP-to-IP Gateway, or BSC - Border Session Controller, in Cisco parlance.
Yes it's supported, however Rb will need to run and IP-to-IP image, which image name ends with _isv, at that point it will be able to connect VoIP even when different signaling protocols are used, and do (some limited) transcoding, plus other things
Be courteous, in exchange of received answers, rate useful posts!
ciscoforum Fri, 05/04/2007 - 09:19
Thanks. Do you know what's the commmand? or which link has the detailed information?
paolo bevilacqua Fri, 05/04/2007 - 10:25
  • Hall of Fame,
    Founding Member
These are the commands
voice service voip
allow-connections h323 to h323 (or any combination you are using)
dial-peer voice XX voip
codec transparent
that's it.
As a courtesy to those providing answers, please rate all posts using the scrollbox below!
paolo bevilacqua Tue, 05/08/2007 - 12:02
  • Hall of Fame,
    Founding Member
Or configure a voice-class that lists the codecs you want allow the endpoints to negotiate.
Remember to rate useful posts as an appreciation for those providing answers!
kelvin.blair Tue, 05/08/2007 - 13:54
  • Silver, 250 points or more
You can either use the voice class or transparent. The transparent will use what ever the other ends offers. The voice class will allow you to set a restriction on what codecs to use and it is up to both parties to decide on which to use. One problem with this is that if both parties disagree on codec, then you will get a codec mismatch and the call will be busy out.
ciscoforum Sun, 05/13/2007 - 18:59
So then I don't think we need _ivs image since the following commands is supported in voiceip image too, right?
voice service voip
paolo bevilacqua Sun, 05/13/2007 - 20:07
  • Hall of Fame,
    Founding Member
I think you do. The commands are there in all versions.
