cameron.moody Thu, 05/03/2007 - 18:22
Hi Join,
You can use the IOS Feature Navigator located at http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
You will however need a CCO login to be able to use this tool. It will then list the features that the particular IOS supports. You can also use it to search for IOS compatible with your particular hardware and memory requirements of each etc.
Hope this helps.
join_sn09 Thu, 05/03/2007 - 20:55
Dear Cameron,
Thank you for show me.
Best Regards,
Join
