"show ip route" - Routing table is empty
May 3rd, 2007
Hi folks,
I configured a default gateway and a static default route on my
cat4506 switch running 12.1(19)EW2.
ip default-gateway X.X.X.X
ip route 0.0.0.0 0.0.0.0 X.X.X.X
I issued show ip route and nothing displays.
#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B -
BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS
inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
It should have at least show a gateway of last resort in the routing
table or a " S* 0.0.0.0/0 [1/0] via X.X.X.X " entry.. Right?
I have verified that ip routing is enabled.
Why is the routing table empty? Any ideas?
Carol
Overall Rating: 4 (1 ratings)
mohammedmahmoud Thu, 05/03/2007 - 22:10
  • Green, 3000 points or more
For a route to be entered into the routing table its next-hop must be reachable, so the reason that these routes are not inserted into the routing table is that there is no up/up interface that the next-hop would be reachable upon.
HTH, please rate if it does help,
Mohammed Mahmoud.
carogo Thu, 05/03/2007 - 22:30
Hi Mohammed,
Thanks for the response. The switch is configured with a management vlan with an ip address.. This is the only L3 address configured in the switch.
I checked sh int and it's UP, UP.
So it could not be the problem right?
Carol
mohammedmahmoud Thu, 05/03/2007 - 22:40
No it is still the problem, if the next-hop of the static routes is not recursive via the ip address under the VLAN interface it would still not enter the routing table.
example:
Router#sh ip int brief
Interface IP-Address OK? Method Status Prot
ocol
Loopback0 192.168.99.1 YES manual up up
ip route 0.0.0.0 0.0.0.0 10.10.10.1
Router#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
C 192.168.99.0/24 is directly connected, Loopback0
--> Since the next-hop of my static route "10.10.10.1" is not recursive reachable via the ip address of the interface "192.168.99.0" then the route is never entered into the routing table.
Mohammed Mahmoud.
