05-03-2007 10:51 PM
HI,
I have asa5510 with security plus license.
asa 7.2 version.
It shows only 2 webvpn license.
Can you tell me how to increase this. we have purchased for the ssl vpn license.
thanks
raj
05-04-2007 06:55 AM
Cisco ASA 5510 Security Plus bundle
Includes 5 Fast Ethernet interfaces, stateful firewall, 250 IPsec VPN peers, 2 SSL VPN peers, Active/Standby high availability, 3DES/AES license, and 1 expansion slot
So, you should have only 2 webvpn license.
If you would like to increase the webvpn license, then you have to purchase license for the number of webvpn connections you would need.
Hope this helps.
Cheers
Gilbert
05-05-2007 09:18 AM
I already bought this license but i want to know the location for this license to download it
05-07-2007 05:49 AM
If you already bought the license, then the activation key that was given to you should be inserted using the command
activation-key xxxxx xxxx xxxx xxxxx
And then do "wr mem" and reboot the ASA.
Your license for SSL will be activated.
There is no place to download the key - it should have been sent to you. If not, contact the vendor you bought the ASA from and ask them to get the key for you.
Gilbert
