8021.q trunk on switch port
May 3rd, 2007
hi...how ip phone make trunk with switch port? does the switch at least need dynamic mode(auto,desirable,...). some doc said that we dont need explicitly configure switchport to be trunk.. does it mean dynamic port(auto,desirable,..) is enough which is enabled by default from factory? tx
paolo bevilacqua Fri, 05/04/2007 - 00:30
  • Hall of Fame,
    Founding Member
Yes default is enough. Then add "switchport voice vlan XX" and you are all set.
