IP-EIGRP: Callback: callbackup_routes
May 4th, 2007
I have two routers with static routes configured which are then redistributed into eigrp on the second router the routes are weighted 200 as this is a backup route every so often traffic starts to take the backup link and i get the message below in the log:
P-EIGRP: Callback: callbackup_routes 172.36.0.0/16
*Apr 18 08:40:58.813: IP-EIGRP: Callback: callbackup_routes 172.32.0.0/15
*Apr 18 08:40:58.813: IP-EIGRP: Callback: callbackup_routes 172.34.0.0/16
*Apr 18 08:40:58.813: IP-EIGRP: Callback: callbackup_routes 172.20.0.0/16
Any ideas what is causing this?
cheers
Kev
royalblues Fri, 05/04/2007 - 03:57
Kev,
Do you see any logs for any flaps of the EIGRP neighbor relationship?
IP-EIGRP: Callback: callbackup_routes means at some point, EIGRP attempted to install routes to the destinations and failed, most commonly because of the existence of a route with a better administrative distance.
When this occurs, EIGRP registers its route as a backup route. When the better route disappears from the routing table, EIGRP is called back through callbackup_routes so that it can attempt to reinstall the routes that it is holding in the topology table.
HTH, rate if it does
Narayan
royalblues Fri, 05/04/2007 - 05:06
Kevin,
Do you have the eigrp log-neighbor-changes commannd under EIGRP process?
Narayan
kevinhobson2000 Fri, 05/04/2007 - 05:18
Narayan,
Ive just checked the config and whoever originally configured this has configured it not to.
Cheers
Kev
royalblues Fri, 05/04/2007 - 06:07
Can you have this configured and then check the logs to see whether you see neighbor flaps along with the other logs
Narayan
