URL time out
May 4th, 2007
I am having an issue to connect to url through CSS on web server, but I can access it locally.
Any thing wrong with my config,
service AA-webAdvertising-2
ip address 10.194.17.129
protocol tcp
port 80
keepalive type tcp
keepalive port 80
active
content AA-webAdvertising-2
add service AA-webAdvertising-2
protocol tcp
port 80
url "/nie/*" dql x.y.z
vip address 10.194.17.120
advanced-balance sticky-srcip
no persistent
flow-timeout-multiplier 300
active
"sh con "
SFP: 1/1 Index: 386 <10.194.17.120> TCP Port 80 Streamed
WWW.x.y.z.CO.UK/nie/index.php
Syed Iftekhar Ahmed Fri, 05/04/2007 - 10:35
  • Blue, 1500 points or more
Where is the client? Is it in the same subnet where real servers are? If yes then you will have to source nat the traffic to make sure that the return traffic doesnt bypass CSS.
If thats not the case, Make the content rule simple (remove url under content rule or use url "/*") and check if it works.
Syed
