05-04-2007 05:54 AM - edited 07-03-2021 02:01 PM
hello I have a question .
I have two ssid but i must subnet in 30 networks, each ssid must be with 15 vlan like minimum...
the case is that I have but of 30 sites with two subnetworks wifi.....
thank you....
Solved! Go to Solution.
05-10-2007 10:49 AM
Each SSID can be mapped to only one VLAN, so if you want to have 15 WLANs you should have 15 SSIDs. Which wireless solution are you using? Autonomous or Centralized solution?
05-10-2007 10:49 AM
05-10-2007 10:55 AM
ok thank you for help, but the situation was solved.
we are using wlc4404
