ISDN problems
May 4th, 2007
I have had no experience with ISDN...teacher wanted to know if anyone could set this up, so I tried. I'm in semester 2, and this is apparently semester 4 stuff....
NETWORK -- ROUTER -- ATLAS550 -- ROUTER -- NETWORK
Sorry I can't give you a better looking topology....but basically, I'm just using the Atlas550 to simulate the provider, I want to connect to two networks together through that. The two routers I'm using are 800 series. Here is the configuration for one of them (the other one isn't much different except for SPIDs, ip address, etc)
sh ru
Building configuration...
Current configuration : 758 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname BRI-2
enable secret xxx
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-ni
interface Ethernet0
ip address 192.168.14.2 255.255.255.0
interface BRI0
ip address 194.168.14.2 255.255.255.0
dialer rotary-group 1
isdn spid1 51055510000002 5551002
isdn spid2 51055510010002 5551003
no cdp enable
interface Dialer0
no ip address
no cdp enable
interface Dialer1
no ip address
no cdp enable
ip http server
ip classless
line con 0
password cisco
logging synchronous
login
stopbits 1
line vty 0 4
password cisco
login
end
BRI-2#sh isdn stat
Global ISDN Switchtype = basic-ni
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI = 65, Ces = 2, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
TEI 64, ces = 1, state = 5(init)
spid1 configured, spid1 sent, spid1 valid
Endpoint ID Info: epsf = 0, usid = 70, tid = 1
TEI 65, ces = 2, state = 5(init)
spid2 configured, spid2 sent, spid2 valid
Endpoint ID Info: epsf = 0, usid = 70, tid = 2
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 0, L2 Session ID = 20
Total Allocated ISDN CCBs = 0
BRI-2#sh int bri0
BRI0 is up, line protocol is up (spoofing)
Hardware is BRI with U interface and POTS
Internet address is 194.168.14.2/24
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
DTR is pulsed for 1 seconds on reset
Last input 00:00:08, output 00:00:08, output hang never
Last clearing of "show interface" counters 00:04:54
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
58 packets input, 232 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
58 packets output, 232 bytes, 0 underruns
0 carrier transitions
BRI-2#
I can't get the two SOHO routers to talk to each other...and I'm not sure if the configuration even works, there is supposed to be active calls correct?
Remember, I'm completely new with this stuff, just started testing yesterday with the equipment. Will that configuration work? Or what do I have to add to get it working?
ALSO: I configured the Atlas550 by what it told me in the manual...switch-type and SPIDs are correct. The IP on bri0 on the other router is 194.168.14.1
Ben Hulett
sundar.palaniappan Fri, 05/04/2007 - 06:07
  • Green, 3000 points or more
Ben,
Good you are ahead of the class :-)
Your ISDN status looks good but you are missing some configuration to initiate ISDN. Here's a link that has sample basic ISDN configuration example that should help you fill in the gaps.
http://cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080094abd.shtml
Let us know if you still have any problems getting it to work.
Sundar
