Neverending VPN problem
May 4th, 2007
Again the same problem with l2l VPN:(
Because of ip address changing on ASA, i asked remote side to change Peer ip to the new ip.After that the problem arose. It worked fine before!!!
" [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
[IKEv1]: Group = X.X.X.X, IP = X.X.X.X, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
[IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, IKE MM Initiator FSM error history (struct &0xf239f30) <state>, <event>: MM_DONE, EV_ERROR-->MM_WAIT_MSG6, EV_PROB_AUTH_FAIL-->MM_WAIT_MSG6, EV_TIMEOUT-->MM_WAIT_MSG6, NullEvent-->MM_SND_MSG5, EV_SND_MSG-->MM_SND_MSG5, EV_START_TMR-->MM_SND_MSG5, EV_RESEND_MSG-->MM_WAIT_MSG6, EV_TIMEOUT
[IKEv1 DEBUG]: Group = X.X.X.X, IP = X.X.X.X, IKE SA MM:fb2a1c30 terminating: flags 0x0100c022, refcnt 0, tuncnt 0
[IKEv1]: Group = X.X.X.X, IP = X.X.X.X, Removing peer from peer table failed, no match!
[IKEv1]: Group = X.X.X.X, IP = X.X.X.X, Error: Unable to remove PeerTblEntry
What can be reason?
How Can i "restart" the VPN on my ASA? Because i don't think that there is a problem with configuration.
