VPN Client FTP Issue
May 4th, 2007
We have an issue with the Cisco VPN Client and FTP access. When the client is not connected, we can not establish a public FTP via DOS. We have a batch file that runs to download a file off our FTP server. The session just hangs and no ftp commands will process. If we go into the control panel and shut off the cisco vpn client service, the FTP will work just fine. I have removed the VPN client and reinstalled. I have disabled the windows firewall and no luck. Has anyone seen anything like this before? What should I check next?
acomiskey Fri, 05/04/2007 - 06:58
Does your batch file use public ip address of the ftp server? That may be your issue.
mike.walter Fri, 05/04/2007 - 07:10
Yes, it does use a public IP. It wasn't a problem before, this just started happening. Is there a work around?
acomiskey Fri, 05/04/2007 - 07:13
It began without any configuration changes at headend device? You're sure you were able to do this while connected to the vpn before? Do you use split tunneling?
mike.walter Fri, 05/04/2007 - 07:19
Yes. Nothing has changed on our 515E. Please note as well, the trouble is when we aren't connected to the PIX 515E.
