Translation Pattern Called Number
May 4th, 2007
I have a translation pattern, 8881, which translates to 8888, and then rings the phone with this extension (8888). When 8881 is called, the caller sees To Hotline (8888) in their display, since this is the actual number that is ringing. Is there any way to mask this so that it always shows the original dialed number (To 8881) in the callers display (even though it's ringing 8888)? If I set "Connected Line ID presentation" to restricted on the translation pattern, it shows Unknown Number, which isn't desirable.
Thanks for the help.
jbayuka Thu, 05/10/2007 - 06:02
  • Bronze, 100 points or more
use the phone number mask in CCM admin page for the desired number pattern
