problem AP 1220B don't boot up
May 4th, 2007
Hi all,
My AP1220(VxWorks) don't boot up after I tried to reset his password. After 2sec he shows all 3 LEDs in steady green.
Console shows this info at boot time
esting DRAM...
(press <esc> to bypass)
DRAM OK
Power-on reset.
Copyright 1996-2000 Cisco Systems, Inc.
Copyright 1984-2000 Wind River Systems, Inc.
System ID: 0012000207A6
Motherboard: IBM405 200MHz, 8192KB FLASH, 16384KB DRAM, Revision 05
Bootstrap Ver. 1.00: FLASH, CRC 1C914641 (OK)
Initialization: OK
and that's all
What to do with AP?
How to load new VXWorks or IOS image??
thank you for advice
Rob Huffman Fri, 05/04/2007 - 09:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Kestutis,
Have a look at the following;
Verify that the connection settings in the terminal application are 9600-8-None-1 and NO flow control (not hardware or software).
From this doc;
Recover from a Failure
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a008019fea0.shtml#topic2
Reset the VxWorks AP;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_password_recovery09186a00800949d0.shtml
Part of this comprhensive doc;
Upgrade Cisco Aironet AP1200 to IOS
Hope this helps!
Rob
kestutismeskonis Fri, 05/04/2007 - 21:05
Nothing helps. First I didn't upgrade my 1200Vx to IOS. Problem arised after I tried to reset password. So first place:I need to boot AP to normal VxWorks or some Rommon mode.
In my case I can't input any characters and I don't see any menu except output in hyperterminal (previous mentioned).
thanks
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
