CSS - Syslog and command line logging
May 4th, 2007
I am attempting to capture all command line input to syslog for audit purposes.
However, using the documented approach
logging subsystem netman level info-6
logging commands enable
logging host facility 1 log-level info-6
I also get lines for the activity that the CMD-SCHED is completing.
Is there a way to suppress these additional messages from going to sysout.
aghaznavi Thu, 05/10/2007 - 11:25
You can redirect the message from CSS to a diffwerent device. Enable logging subsystem
CSS150-2(config)# logging host ?
Of the form a.b.c.d or host.domain.com
facility Syslogd facility level
Syed Iftekhar Ahmed Thu, 05/10/2007 - 12:24
There are standard messages per each log level.
You cannot suppress a subset of these messages.
You will need to filter out these messages on syslog server.
