Does AP1242 used as WGB supports PEAP?
May 4th, 2007
We are currently testing AP1242 (used as Workgroup bridge) to replace our current client bridge device that uses PEAPv0 as authentication protocol. The assumption was that AP1242 (as WGB) supports PEAP (v0 or v1). But the ACS server failure log is telling us differently ("EAP Type not configured"). Does AP1242 (as WGB) supports PEAP? What authentication protocol does AP1242 (as WGB) uses? Is it EAP-FAST? Any info you can share is much appreciated.
bwalchez Thu, 05/10/2007 - 10:50
I don't think there is any restriction that WGB does not support PEAP. WGB will support any EAP authentication. If its not working, we need to look at the configuration to see if we have missed something. Can u post the configuration?
Trending Topics - Security & Network
