ankbhasi Fri, 05/04/2007 - 08:09
  • Cisco Employee,
Hi Brannon,
SSO is always better then RPR+ if you IOS supports the same because the switchover time with SSO is less then 3 seconds where in RPR+ it is approx 30 seconds.
SSO needs minimum 12.2(18)SXD and as you mentioned you have 12.218 release I will recommed you to opt for NSF with SSO.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008027e4cd.html
Ankur
*Pls rate all helpfull post
Amit Singh Fri, 05/04/2007 - 08:18
  • Cisco Employee,
Brannon,
SRM is the good option rather than RPR+ as RPR+ gives you the switchover arnd 30-60 seconds while SSO gives you subsecond failover with 0-3 seconds.
Starting with IOS 12.2.18 code we default to SSO. RPR+ was used prior to the 12.2.18 Code. Use SSO/NSF for L2/L3 HA. Prior to 12.2.18 code we were supporting SSO/SRM
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/nsfsso.htm
HTH,Please rate if it does.
-amit singh
atif-siddiqui Mon, 01/14/2008 - 13:55
How does SSO/NSF work with MPLS LDP, I am testing and have an MPLS network I do not get 0 - 3 seconds repair time, it is about ~30 Sec same as RPR+
tx
