Gatekeeper with a gateway farm
May 4th, 2007
Hi, do you now if i can do a parcial migration of 2 gateways as gatekeepers endpoints leaving the other gateways as part of the normal voip network. I am asking that because the customer have 10 gateways that conform the h.323 network and he want to test the same network but using a gatekeeper, so if i put only 2 of the gateways as gatekeepers endpoints, these will affect the normal call processing or not?
Thanks in advanced
Jose
Brandon Buffin Fri, 05/04/2007 - 10:37
  • Purple, 4500 points or more
Jose,
This is certainly feasible. Just be sure that you have removed the references to these 2 gateways in route lists, route patterns, etc. and be sure that you have route lists and route patterns in place that point to the new gatekeeper.
Hope this helps. If so, please rate the post.
Brandon
