Appletalk on Catalyst express 500
May 4th, 2007
Just install this switch with default configuration. On our Lan we have mix of windows nd old Mac with Appletalk used for printing and else.
Since i installed this device no more mac work. Is there a way to enable appletalk on the Catalyst express 500
Amit Singh Fri, 05/04/2007 - 10:56
You canot configure Appletalk on CE500.It should work. What is the port role configured for the MAC's. Try configured the port roles to " other " and see if that works.
-amit singh
andypeper66 Fri, 05/04/2007 - 11:28
I will try that over the week end
thx for your info
let you know
