IPCCX 4.0 Custom Variables
May 4th, 2007
I'm currently runnin IPCCX 4.0 Enhanced and i'm trying to write a script that write the information to the customVarlableX on the db_cra database to generate a custom variable report by using the Historical Reports client, i've tryied by using the Set Session info step and the Set Enterprise call info but without results.
If you have an answer for this issue please let me know.
Claudio Rivas.
Clifford McGlamry Wed, 05/16/2007 - 16:56
Hi Claudio,
I ran into this same issue. The problem is that the documentation is incorrect. In order to set the values into the customVariable fields in the database, you use the SET ENTERPRISE INFO function. On the general tab, you will see 12 fields that can be populated. PeripheralVariable1 maps to CustomVariable1 in the database and so on. I faced this same issue today, and found this solution with some help. I have tested it and it works.
The set session info method specified in the documentation does NOT work. Don't waste your time banging your head against the wall trying to get it forced. TAC agreed with me on this today and has opened an internal case to get all their docs that reference this fixed.
