Tranlation Routing Aspect ACD to Cisco CVP
May 4th, 2007
Is there some better documentation and examples describing procedures for translation routing from an Aspect ACD back to Cisco CVP. I have a PDF called "Cisco ICM Software Supplement for Aspect.pdf", and I am already able to TR from CVP to Aspect, but the other direction is harder to figure out.
boyd.lynn Thu, 05/31/2007 - 03:00
In order to use TRs from the Aspect to CVP you have to have a range of DDIs that will deliver the call to the CVP from the Aspect.
i.e 95554441 to 95554445
You also need a CCT that will dial out using the DDI returned from the ICM in one of the Aspect Variables A-E (You can choose which one)
i.e CCT 300 and Variable B
In the TR configuration with Aspect as the routing client the labels should be configured as
where %2 means Variable B
A=1, B=2 etc
