Minimum cable length for SFP-OC3-IR1
djoray
Is there a minimum cable length for the SFP-OC3-IR1 fiber card in a PA-POS-1OC3 port adapter? We are installing a couple of OC-3 circuits and the telco side will be single-mode fiber. Our router will only be about 10 feet away from the telco port and I want to make sure that will work.
2 Accepted Solutions
paolo bevilacqua
With SM IR you are on the boundary of receiver maximum signal and bring the receivers in saturation. It would be prudent to insert an inline optical attenuator of like 5db, or use a MM fiber cable to purposely disperse some energy. The exact value can be calculated by the optical budget values that are published for the equipment you will be using.
jasonrandolph
Telco Port, or from the laser?
IE: is this a direct fiber drop between a remote/carrier location and you, or will this be an OC3 port off of Telco equipment such as a SONET ring/spur?
If it is coming directly off of an emitter source then an attenuator would be prudent or you risk burning out either your SFP or the Telco hardware.
paolo bevilacqua
jasonrandolph
