Unity 4.2(1) port status
May 4th, 2007
I've had an issue with a couple of Unity installs whereby several ports on Unity stop being used by CM until the CM Voice Mail Port is manually reset. I've installed the latest TSP on Unity (8.1.3), but it doesn't seem to resolve the issue. Has anyone else run into this?
gogasca Fri, 05/04/2007 - 21:45
The VM port still show registered in CCM ?
Any error in EV in Unity server?
Exact CCM ver?
What you get fast busy? Ring no answeR?
Make sure you have followed the integration guide.
this Unity server is in Failover?
Other Unity server in the network that may be using the same VM port name?
Let us know
shikamarunara Fri, 05/04/2007 - 21:55
CM 4.2.3 with Unity 4.2.1. According to TAC, there's a bug on report that seems to be related to blind transfers. An Engineering Special has been released for it, will install it on my test bed and see if it works.
shikamarunara Mon, 05/07/2007 - 08:12
True enough, these are the symptoms of the issue and resetting the ports temporarily solves the issue. However, I am looking for a permanent solution. TAC believes that upgrading CM 4.2.3 to 4.2.3ES15 solves the problem.
