05-04-2007 01:15 PM - edited 02-21-2020 01:30 AM
Can you configure both clientless and sslvpn client (svc) on the same device? Can a user access both? That is, for example if you configure clientless for OWA and svc for another application, will a user be able to access/use both?
Thanks!!
Solved! Go to Solution.
05-05-2007 03:37 PM
Yes you can, the way we did it was to create a group policy for each with an alias for each and to enable the drop down box for group policy selection for the user. So when a user accesses the WebVPN site under the username and password boxes there is a box to select which way they want to connect.
05-05-2007 03:37 PM
05-06-2007 05:53 AM
Excellent! I have setup a lab environment for this on Friday so I'll try out your solution on Monday and let you know how it goes. Thank you so much!!!
05-07-2007 11:42 AM
Yes, it worked like a charm. Thanks! I had to upgrade to version 7.1 or newer have sslvpn client capability but other than that it was pretty straightforwad and painless. Cheers!
