Ethernet0 is up, line protocol is down
May 4th, 2007
Exactly that.
show in e 0
Hardware is Lance, address is 00e0.b02d.4258 (bia 00e0.b02d.4258)
Internet address is 192.168.0.17/29
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
reliability 128/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Last input never, output 00:00:05, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
522 packets output, 32115 bytes, 0 underruns
522 output errors, 0 collisions, 8 interface resets
522 lost carrier, 0 no carrier
Cable is good. I am lost help is appreciated.
Overall Rating: 5 (2 ratings)
sundar.palaniappan Fri, 05/04/2007 - 13:33
  • Green, 3000 points or more
Is this a switch or a router. What's on the other end of the connection. How did you verify the cable is good. Are you using the right type of cable, crossover/straighthrough etc?
Sundar
bruce.cowan Fri, 05/04/2007 - 13:39
This is a router and I am using a good crossover. Tested by use with another device.
sundar.palaniappan Fri, 05/04/2007 - 13:44
Is it connected to a switch or a router. If it's a switch then you need to use a straight-through cable.
vgrigaliunas Fri, 05/04/2007 - 13:58
I assume the router interface is enabled (sorry ;-))? Can you do a hard loopback on both interfaces ?
bruce.cowan Fri, 05/04/2007 - 14:13
I forgot to state that it is connecting to a pc. I issued the no shutdown command once the ip and subnet were assigned. I will do the lb and post results
bruce.cowan Fri, 05/04/2007 - 14:24
I entered the command loopback and now
Encapsulation ARPA, loopback set
982 packets output, 59715 bytes, 0 underruns
982 output errors, 0 collisions, 11 interface resets
982 lost carrier, 0 no carrier
still down. If that was not what u meant by hard lb please let me know.
jasonrandolph Fri, 05/04/2007 - 15:05
Try hard-seting the speed/duplex on the PC's NIC to 10/half... Many newer NICs will not come up if duplex between the network device and PC do not match.
10/100 Ethernet has no provisions in it for duplex negotiation.
vgrigaliunas Mon, 05/07/2007 - 10:01
I assume this is UTP ? We have UTP loopback plugs which loop the proper wires back onto themselves to make a "hard" loopback to see if the interfaces are OK. You can probably make one yourself provided you have the UTP pinouts...does the PC interface come up on a different port of the router did you say ?
scottmac Fri, 05/04/2007 - 16:13
There are two things that (normally) can cause this:
1) Try a new cable, in your case, probably a cross-over cable
2) An invalid ENCAPS type for Ethernet
Good Luck
Scott
Richard Burts Mon, 05/07/2007 - 18:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Bruce
Based on this in the output that you posted:
Hardware is Lance
I believe that this interface is 10 Mb half duplex. My guess is that the PC is not matching, probably because the PC is attempting to negotiate speed and duplex but the router interface does not negotiate. Try setting the PC to 10 half duplex and let us know what happens.
Rick
bruce.cowan Tue, 05/08/2007 - 05:43
I appreciate the help. I will be checking the pc nic this after noon and all the other suggestions. I do appreciate all the help.
Bruce
