May 4th, 2007
I have deployed 2 catalyst 6500 with 2x sup32 for each cat, I try to connect both switch?s by two 10G interfaces on each chassis (one in the standby and one in the active) but with no look, the only 10G interfaces that came up was the 10G interface from the standby sup32, the 10G from the active sup did not appear in the show run.
Is this beaver normal, can I use the 10G interfaces from both redundant/standby sup32 ?
Thanks in advance
Amit Singh Thu, 05/10/2007 - 19:10
This behaviour is not normal. You can use both the 10G interfaces on active/standby sup engines. Check for connectivity issue on the 10G interfaces, loose cable, loose connector etc.
-amit singh
