telnet connection refused to terminal server router
Answered Question
May 4th, 2007
I have a terminal server router of which cable number 4 and 5 i have connected to my PC at the serial port. however when try to do telnet iam not able to get the console.
when i try to do telnet 10.201.200.15 2035 it return an error connection refused
here is my configuration file
****************** configuration ***
version 12.3
hostname ts-cluster-c
boot-start-marker
boot-end-marker
enable secret 5 $1$V5Nu$RGD3V1a3dJyh4Q6/7NFtH1
enable password eskimo66
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
no ftp-server write-enable
interface FastEthernet0/0
ip address 10.201.200.15 255.255.255.0
no ip route-cache
duplex auto
speed auto
no mop enabled
interface Group-Async0
physical-layer async
no ip address
no group-range
ip default-gateway 10.201.200.1
ip classless
ip http server
line con 0
line 33 48
line aux 0
line vty 0 4
password cisco
login
end
Correct Answer by mohammedmahmoud about 9 years 8 months ago
You need the following:
under the async interface:
--> physical-layer async
--> async mode interactive
under the async TTY line(s) (33-48):
--> transport input telnet
--> stopbits 1
Plus make sure that the interface you are using its ip for the reverse telnet is up/up, and its recommended to use a loopback interface for this issue.
HTH, please rate if it does help,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
Correct Answer
mohammedmahmoud Fri, 05/04/2007 - 21:36
--> stopbits 1
Mohammed Mahmoud.
